3/10/2022 10:32 AM | |
Joined: 2/22/2022 Last visit: 7/20/2022 Posts: 1 Rating: (0) |
Hi everyone, i hope you are doing well ? Am having an issue concerning the modbus connection with the SiemensLogo, am trying to connect my siemens Plc to an other Modbus supported Plc ( Jumo700 ), i've tried to connect my logo plc with my pc as both master and slave and it seems to work perfectly. Unlike the case with the JUMO700, i'am thinking the problem is due to wrong settings. am not an expert with the network settings, but i respected the essetials ( same port(502), the correct Ip address),expect for the variable adress am not really sure about, because in the JUMO700 adress are in hexadecimal, and my logo accepts only adress in décimal so i converted the hexadecimal adress to decimal and inserted it to my siemns setting as shown in the attahcements. you'll find attached my settings informations. Thanks in advance ------------------------------------------------------------------------------------------ AttachmentModbus_settings.zip (204 Downloads) |
Last edited by: Jen_Moderator at: 03/10/2022 11:03:18New subject after splitting |
