2/12/2024 11:28 AM | |
Joined: 7/27/2023 Last visit: 5/22/2024 Posts: 46 Rating: (4) |
Hi! There is an option in the alarms that if you enable the "Trigger in action" property, the "GMsgFunction() function is executed, which allows you to execute whatever you want when the alarm that has this property activated occurs. It is programmed by script. It is explained in detail in the following FAQ in section 7. - How do you display and operate alarms in Runtime?: https://support.industry.siemens.com/cs/ww/en/view/25554088 |
