7/31/2024 8:11 AM | |
Joined: 5/6/2022 Last visit: 7/31/2024 Posts: 437 Rating:
Hi AutoGen_4955742, First of all, I would like to tell you that since this is a discontinued display my knowledge is not very extensive but I would like to ask you the following: - I understand that you have correctly inserted the card in the panel, right? - Have you tried with other different cards to see if the same thing happens? - I would recommend resetting the panel to factory defaults and restarting it to see if the same message keeps popping up. Best regards!
