6/28/2009 2:24 PM | |
Posts: 34 Rating: (2) |
hi Fibre optic Hsync module will take care of hot redundancy. this will comes with Hsystem itself For Pc requirement check this link http://support.automation.siemens.com/WW/view/en/29501428Siemens Wincc and Step 7 License comes in Pen drive and it can be moved to any of the hard disk drive regards dilipan |
6/28/2009 5:55 PM | |
Joined: 3/18/2009 Last visit: 5/6/2024 Posts: 306 Rating: (94) |
The Asian WinCC basic systems (RT and RC) are secured by a hardware lock starting with V7.0 SP1. Here is theupdate.
6/29/2009 5:04 PM | |
Joined: 4/5/2006 Last visit: 4/24/2024 Posts: 917 Rating: (63) |
Hello, 1) if you buy H System with boundle order code you'll receive all HW component you need to work in redundant mode; otherwise you have to buy H-Syncmodule to put in CPU own slots and connect them by optical fiber 2)dilipan_calready gave to you a good compatibility answer for that 3) you need a set of licence to your use: WinCC RunTime (RT License) or RC (Runtime and configuration) and you have to know how many tags you need. For redundant connection you need CP1613 and license on your PC. Regards |
