8/10/2012 6:05 PM | |
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665) |
Hello WireGuy; There is still a lot of litterature on the 505 series of PLCs available in the Siemens Support webpages. Just look for the documents using the Search box at right, using "545-1101" as a search string for example. One of the search results you would find is this manual: 545 Tech Overview Man Rel. 2.1 This information can be loacted in the manual: Program Storage The SIMATIC 545 offers the option of saving your RLL program in a non-volatile form by downloading it to an Electrically Erasable Programmable Read-Only Memory (EEPROM) integrated circuit. A separate programming device is not necessary. Once programmed, an EEPROM can be removed and used in any SIMATIC 545 as required. You can also use an Erasable Programmable Read Only Memory (EPROM) programmer to copy the EEPROM to an EPROM integrated circuit. This makes program duplication much easier if you have multiple controllers that use the same program. Accessory Equipment The following accessory equipment is available as spare parts....User EEPROMs (part #2587681–8022) and EPROM (part # 2587681–8023) Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 8/10/2012 7:03 PMLast edited by: dchartier at: 8/10/2012 6:06 PM |
8/10/2012 6:41 PM | |
Posts: 510 Rating: (117)
I did a Google search of the part number and found these resources: http://support.automation.siemens.com/WW/view/en/4096632 http://www.classicautomation.com/catalog/ProductDetail.aspx?partnum=2587681-8022 http://www.siemenssupply.com/dcs/siemens/simatic-ti-other/2587681-8022 Hope this helps billwest |
