9/10/2007 8:47 AM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating: (121) |
Hi, i found the follwing Info. => http://support.automation.siemens.com/WW/view/en/26290948 What MMC Card did you use? ( 128 or 64 MByte) When i understand the info correctly, then the user should better use the 64MByte Card and not the 128MByte! The best are you conatact the customer support from SIEMENS directly. Regards, |
