9/3/2008 12:53 PM | |
Posts: 133 Rating: (9) |
Hi Kaizer Check out this document. Have a look under OP77B for the list of communication cables and part numbersyou can use. It might be advisible to do a firmware update before proceeding with your project download. (You can do this in WinCC Flexible via the Download options) You can do this using a serial cable if all else fails. Cheerz Hope this helps AttachmentPanels_Possibilities_of_connections.pdf (613 Downloads) |
