1/29/2019 11:34 PM | |
Posts: 6 Rating: (0) |
Hello, i need to install the pyodbc in Python i use pip3 install pyodbc but i take ...[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)... i try also to change a date with command : date 111118102018 but with no success ... i use a IOT 2000 with image V2.2.0 Can you help me ? Thanks
Last edited by: FabrizioMas at: 1/29/2019 11:40:25 PMLast edited by: Jen_Moderator at: 1/30/2019 10:07:16 AMNew subject after splitting |
1/30/2019 9:02 AM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating: (379)
Hi, why don't you set the current time? Try it with date 013009002019 (this is now). But anyway, the installation could not be done. For installing pyodbc you will need the ODBC header files. You can download them and install it from source.
Check if the installation worked with:
Best regards! |
