8/8/2019 12:50 PM | |
Joined: 7/1/2016 Last visit: 4/27/2024 Posts: 8 Rating: (0) |
Hii... Greetings for the day... I am getting below error in wincc rt professional scada, please suggest the solution "error 3706 provider cannot be found. it may not be properly installed" Thank you Krishi ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/09/2019 09:03:17New subject after splitting |
8/9/2019 11:56 AM | |
Joined: 11/14/2018 Last visit: 10/31/2023 Posts: 502 Rating: (69) |
Hello Krishi, could you explain, which Version of RT Professional you are using. And is there a specific situation in which the error occurs? Furthermore in the link below, you can find good advice of which information you should provide, if you are looking for support: Greetings, Nzett11 |
If I could help you, be so kind and rate my contribution. :) |
8/9/2019 12:12 PM | |
Joined: 7/5/2013 Last visit: 6/7/2024 Posts: 3098 Rating: (507) |
Hello Krishi, are you using an ADODB or OLEDB connection e.g. to read data from an archive? - Then this MICROSOFT link might help. Regards, Frink |
Pi is exactly three! |
