8/24/2020 8:15 PM | |
Joined: 12/18/2014 Last visit: 8/16/2024 Posts: 33574 Rating:
When it is described in this way in the manual, it means that Siemens only guarantees perfect function up to this distance. You will also be able to use a greater distance, but then that's just trying. However, this refers to a direct connection. If you are connect separated from a switch to LOGO! and to the TDE, then you will probably be able to choose greater distances. How great, I don't know. If you want to be sure, ask the question directly to Siemens via a Support Request.
