1/14/2021 1:26 PM | |
Posts: 9 Rating: (0) |
Hello again, i have found a solution, and wanted to share with you guys. it's a 4-20 MA signal isolator.. plug in.. plug out.. PHOENIX CONTACT | Repeater power supply - MINI MCR-SL-RPS-I-I - 2864422 it'S the simplest way without having modify the wiring as this is a test we are doing to install a sensor cleaner on the process. |
