5/31/2023 4:26 AM | |
Joined: 11/21/2022 Last visit: 6/7/2023 Posts: 2 Rating: (0) |
Hello, I HAVE A FIELD PG M5 FROM SIEMENS. YESTERDAY AFTER WORK WE SHUTDOWN IT NORMALLY,BUT TODAY I TRY TO SWITCH IT ON, IT DOES NOT GETTING ON VIA POWER BUTTON I TRY TO PUSH A POWER BUTTON- NO REACTION,NOTHING / NO NOISE FROM HD NO LEDS INDICATION , I CAHRGED THE BATTERY ALSO AND INDICATION OF BATTERY AFTER SOME TIME SHOWING GREEN STATUS . What can be a problem? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/31/2023 10:28:25New subject after splitting |
5/31/2023 6:23 PM | |
Joined: 7/19/2022 Last visit: 5/22/2024 Posts: 358 Rating: (61) |
Hello NKKHAN, I recommend you open a Support Request so that technical support can advise you if you have to send it for repairs. |
6/5/2023 4:25 AM | |
Yaa, i try without battery, but power button did not work, |
6/8/2023 7:56 PM | |
Joined: 6/8/2023 Last visit: 12/28/2023 Posts: 2 Rating: (0) |
hi, did you manage to solve the problem? |
7/12/2023 3:52 PM | |
Joined: 8/14/2021 Last visit: 7/14/2023 Posts: 13 Rating: (0) |
check whether the power button |
kpee going! |
7/17/2023 1:00 PM | |
Joined: 7/14/2023 Last visit: 10/13/2023 Posts: 1 Rating: (0) |
You can try checking power supply ! |
keep go! |
