10/22/2022 8:39 PM | |
Joined: 10/6/2022 Last visit: 10/29/2022 Posts: 3 Rating: (0) |
Hi now i connect Logo at my Solaredge, port and ID modbus correct and VM i use same than you Can show us your block program? because i not understand how can make code in logo for show this value in lcd screen. i try use a "floating point converter" block, bot the result i see 0,00 what block should I use to call VM 30 and etc ..? i find In this doc. in page17 have all address, when i work fine the first one, then try with other value https://www.solaredge.com/sites/default/files/sunspec-implementation-technical-note.pdf
Last edited by: Jen_Moderator at: 10/24/2022 04:23:44Neue Überschrift nach Splitten |
10/23/2022 4:25 AM | |
Joined: 12/18/2014 Last visit: 5/11/2024 Posts: 33003 Rating: (4078)
In attachment a example. AttachmentSolarEdge.zip (660 Downloads) |
10/29/2022 9:00 AM | |
Hi after many attempts, i understand that my Modbus is not activate in inverter. How to activare Modbus TPC in SolarEdge inverter? this: Enabling Modbus TCP on SolarEdge Inverter
NOW WORK! :) source: https://github.com/WillCodeForCats/solaredge-modbus-multi/wiki/Configuration |
