3/6/2015 1:51 PM | |
Joined: 12/18/2014 Last visit: 5/3/2024 Posts: 32952 Rating: (4073) |
Sorry I don't understand that what you mean. You wrote in first post nothing from excel. Can you upload an example? |
3/6/2015 2:21 PM | |
In attachment an example by AI from PT100/1000. |
3/6/2015 3:30 PM | |
Posts: 2930 Rating: (432)
Hi,
best is to make you an example with your Limits. You use an analog sensor connected to an AI of LOGO!. What is the temperature in deg. depens on the 0....1000 Step in LOGO!?
Example: You use a AM2 RTD and a PT100/1000 Sensor. In this case you Need to scale. This is normaly done in the properties of a FB (analog amplifier for example). If you record AIx, then the value is 0....1000.
Attached is an example with PTx and record of AI and FB (Ax). So you can see the different. Hope this helps AttachmentRec AI_PTx.zip (254 Downloads) |
