8/26/2015 3:17 PM | |
Posts: 31 Rating: (0) |
I do not pretend to be an expert but I had few issue with DOS in the past. You can't just copy the file on a disk, this create a data HD or floppy without boot sector. Typically, you need a DOS floppy to format your HD and create boot sector (use DOS program named FDISK.exe), then pc will be able to boot from the new HD. I sent in att. dos 6.0 floppy image and a FDISK utility screen shot. AttachmentBOOT6_0.zip (651 Downloads) |
