1/1/2016 5:33 PM | |
Posts: 1 Rating: (0) |
Bonjour je suis une débutante en step7. s..v.p je suis à la recherche d'un exemple de code d'un system automatise en step7 et comment faire son supervision sur wincc?. Merci d'avance a tous pour vos aides. c'est trés urgent ( ------------------------------------------------------------------------------------------ |
Last edited by: mmaria22 at: 1/1/2016 5:47:46 PMLast edited by: CS Moderator at: 1/2/2016 7:58:20 AMNew subject after splitting |
1/1/2016 6:35 PM | |
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665) |
Bonjour Maria; Siemens offers many support documents that you can find easily using the Search Box at the right of this page. The important thing if you want to limit the amount and determine the pertinence of the answers is to define precisely what you are looking for. For example, what software will you be using to program the PLC, Step 7 v5.5 (Classic programming software) or TIA Portal (which version is also important). Same thing for the WinCC, are you talking of the WinCC SCADA v7/v8.1, or WinCC V.11/12/13 from TIA Portal, or WinCC Flexible (for oprator panels)? When you have searched for a proper combination, you can filter the replies by looking specifically for manuals, FAQs, downloads... For this particular search, I would try Application Examples as a filter. As an example, I have used the Search Box to look for "Step 7 and WinCC", and filtered for Application Examples. One of the (many) reponses I found was this one, with many different sample configurations to choose from (you can change the language to French if you need to study the examples in your own language, there is a selector "Language" at the top of the page):
Machine-oriented operator control and monitoring in Online Support
https://support.industry.siemens.com/cs/ww/en/view/93905586
Hope this helps, Daniel Chartier |
