(0)| 4/21/2023 1:42 PM | |
Joined: 5/6/2022 Last visit: 1/8/2026 Posts: 589 Rating:
Hi Pfgutierrez37, From the screenshot you share, it seems to me that it may be a failure of the process image of your PLC. You are trying to access address 565. It seems to me that the PLC defaults to 256 depending on the model. Could you check which process image your PLC is reaching and share a screenshot? I share a screenshot where you can find it. I look forward to your reply. Best regards!
