1/7/2018 10:30 AM | |
Joined: 12/1/2011 Last visit: 7/31/2025 Posts: 10 Rating:
Dear Sir, This is regarding OS project downloading from ES to main server (MS). I check above check list shared by you. I guess most of the things are ok. I'm receiving following error message while downloading. ERROR: "Existing errors, The target path on the operator station is invalid." I have attached a photo of an error for your reference. What could be the reason for this error ? Is it possible to share the project file with you for observation? Thank you, Dimuthu ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 1/7/2018 12:00:05 PMNew subject after splitting |
1/19/2018 3:39 PM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello you could also use the official FAQ: https://support.industry.siemens.com/cs/ww/en/view/88780011 Bye Murof |
11/29/2022 10:14 AM | |
Joined: 11/30/2016 Last visit: 2/23/2025 Posts: 1 Rating:
Dear THACDINI, I usually made modifications on graphics and downloaded it . but now this message appear like your message so how you solved it thank you Sabry
12/13/2022 12:32 PM | |
Hello Sabry2016 To help we need a few more details to your question. First i would reset the IM folder and try again, if this does not help we need some more information: https://support.industry.siemens.com/cs/de/en/view/109778709 Bye Murof |
