8/20/2025 12:52 PM | |
Joined: 8/3/2009 Last visit: 9/15/2025 Posts: 16409 Rating:
Hello @AutoGen_691469 So from the screenshots we can see you use TIA V20. The WinCC Professional RT has to be installed on teh engineering system if you want to run the Simulation or also the RT (and it has to be of course installed on a PC where only the Runtiem should run). you can dowload it here: https://support.industry.siemens.com/cs/de/en/view/109963703 Bye Murof |
