(0)| 1/16/2026 12:17 PM | |
Joined: 10/11/2006 Last visit: 1/20/2026 Posts: 6071 Rating:
Hello, it is only available for V18. Maybe it is possible to copy the source code with V18 and copy it in a V17 project.
https://support.industry.siemens.com/cs/ww/en/view/109821017 |
With best regards, |
| 1/16/2026 1:50 PM | |
Joined: 7/7/2010 Last visit: 1/20/2026 Posts: 16389 Rating:
This is the support link for that FB: mc_gmc_mp_asia.cn@siemens.com I suggest copy/pasting your original topic posting and emailing to that support email address. They have the original source and are likely the only group that provide what you seek - unless the FB is not KNP (not password protected). If you already downloaded the FB, presumably from this link: https://support.industry.siemens.com/cs/document/109821017 then, you can use Portal v18 to open the applications project, v18 library, and see if you can view all the source code inside the FB and associated components. If so, it should be relatively straightforward to export / generate source files from V18, then tweak the exported files (if needed) so they will import into V17. That said, unless your customer is paying extra for V17, I suggest letting them know "for no extra cost, we will provide source in V18 so you get at least a year of Siemens Support". But, if they required V17, mention that without Siemens Support during the warranty period, any Siemens support costs - associated with supporting past end-of-life software - will be passed on to the customer... Or something like that with better wording, plus whatever legal stuff might be required in your country (and that of the customer) when it comes to warranties. (Might require special wording, disclaimers, or whatever to stay "legal" is all I'm saying).
science guy |
