7/27/2018 1:46 PM | |
Joined: 4/28/2015 Last visit: 8/20/2025 Posts: 20 Rating:
Dear Johny I believe you talk about the old touch and web and not Desigo Control Point. If I am correct please check the following documents, they will help you to setup the alarm routing. In the document CM111029en_06 is noted (Chapter 2.8): Commission alarm routing with PX Web (see the PX Web configuration guide). In the second document (CM110763en_12) you can find in the below chapter the DNS settings: 5.2 The Network tab AttachmentCM111029en_06.pdf (698 Downloads) |
7/27/2018 1:47 PM | |
In the second document (CM110763en_12) you can find in the below chapter the DNS settings: 5.2 The Network tab AttachmentCM110763en_12.pdf (629 Downloads) |
