(0)| 1/29/2020 11:06 AM | |
Joined: 4/4/2011 Last visit: 1/13/2026 Posts: 65 Rating:
Hi! If you did not stopped the CPU by PG , then you can search your program to see what triggered the stop. System Software for S7-300/400 System and Standard Functions Volume 1 and Volume 2. Up here you can read more about system functions/function blocks. If SFB20 is programmed, then a rising edge at REQ input will put the CPU in STOP. SFB 20 is "Changing a Remote device to stop state". Have a read and check your program. Also check other threads already in the forum regarding the issue. Hope it helps, Mihai. |
Learn, unlearn, relearn... |
