12/14/2022 3:11 PM | |
Joined: 7/19/2022 Last visit: 6/21/2024 Posts: 370 Rating: (61) |
Hi abmarcan, Try transferring the last V17 image to your panel again, with Prosave and the "Factory Reset" option. Then transfer the project again and perform the configuration for the web server in the panel. |
12/22/2023 9:43 PM | |
Joined: 8/13/2018 Last visit: 2/29/2024 Posts: 2 Rating: (0) |
Did you manage to fix this issue, i have the same problem. |
