10/11/2022 5:54 AM | |
Joined: 1/30/2020 Last visit: 7/19/2025 Posts: 3 Rating:
Good day I need an assistance in converting the PDB file into TIA portal Ver. 14, I am unable to install WinCC Flexible2008 SP2, and SP2 can't migrate PDB. I have a breakdown on one of my machines. I have an HMI 6AV2 124-0GC01-0AX0 TP700 Comfort. Please assist. please change the format from JPG to PDB. Kind Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/11/2022 11:08:06New subject after splitting |
10/11/2022 7:04 AM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello here are manuals of the two steps for the migration of a Protool project to TIA Portal/Comfort Panel: https://support.industry.siemens.com/cs/ww/en/view/18796902 https://support.industry.siemens.com/cs/ww/en/view/49752044 Bye Murof |
Last edited by: Murof at: 10/11/2022 07:05:08If this Information really helps, you could use the Rate function |
10/11/2022 8:10 AM | |
Thank you for the information. My challange is in installing WinCCFlexable SP 2, I already have service pack 3 without migration. |
10/13/2022 9:51 AM | |
Hello You cannot install two Versions on one system. I recommend using a Virtual Machine with a suitable Windows Operating System for WinCC flexible 2008 SP2. Check the compatibility with Check Tool: https://support.industry.siemens.com/cs/ww/en/view/64847781 Also you can download the WinCC flexible 2008 SP2 if you do not have the installation dvds: https://support.industry.siemens.com/cs/ww/en/view/100777999 Bye Murof |
