(0)| 9/14/2019 6:45 AM | |
Joined: 7/5/2013 Last visit: 12/19/2025 Posts: 3266 Rating:
Hello luismarcelo, I guess you run a WinCC flexible application on a PC with a full Windows OS. Then this FAQ might help. There you find how to access an SQL database and how to run a querry. Regards, Frink |
Pi is exactly three! |
| 9/15/2019 6:12 AM | |
Hello luismarcelo, how did you store the "procedure"? Is it a text-file, maybe with extention "sql"? See: On a PC with WinCC flexible, how can you use a script to save and read out data in a text file? Then you could read the sql-querry from the file and use it with the script described in the link of my first post here. Regards, Frink |
| 7/13/2021 9:35 AM |
Posts: 1 Rating:
I came here looking for an answer and all I can see is that the only person answering not even knows what a stored procedure is :/ |
| 7/13/2021 10:53 AM | |
Posts: 1086 Rating:
Hi, instead of blaming someone I recommend to post your issue/ question. No one knows, what information future users are searching for |
