(0)| 8/13/2023 11:30 AM | |
Posts: 1 Rating:
Dear Concern, Have a nice day. Than I remove the bus bar, than turn on power again. But same led showing again. But When I turn on my hydraulic system, Than there is no Led on the power supply. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/14/2023 11:24:35New subject after splitting |
| 8/15/2023 1:16 AM | |
Joined: 10/17/2007 Last visit: 12/23/2025 Posts: 4566 Rating:
You have ONE Infeed module far right side one , which supply control voltages and also DC 600V,and 2 Monitor Modules, which only relay the control voltage. --most important is Infeed, you need make sure it is good. See my picture attached. doing like this,: disconnect Infeed module from other, (disconnect flat cable). find 2 spare terminal blocks ( If no, you need use original blocks but take picture remember original wires #), on the 2 blocks making jumper like my picture maked RED wires. Don't insert blocks, power up the machine , you should see Green LED on, then insert the block wirh wire # 63-9, 64-9, you will see Green LED off, then you insert Block with #9-48-112, this time the yellow Led should be on, and you will have DC600V. , notes 2 iwres block NS1-NS2 should be insert. If yellow LED not ON your infeed has problem AttachmentInfeed_jumps.pdf (870 Downloads) |
