6/2/2020 7:25 AM | |
Joined: 11/29/2014 Last visit: 9/13/2024 Posts: 96 Rating:
Dear Experts/ Members, Is there any PID block in PCS7 which uses a velocity form algorithm of the PID equation? If anyone has used it please share details of blocks. I am not able to find it in siemens. Rockwell has same block. I have attached file for reference. Thanks & Regards, Dhaval Abotiyawala. Attachmentlogix-wp008_-en-p.pdf (296 Downloads) |
6/2/2020 9:37 AM | |
Joined: 3/14/2008 Last visit: 9/17/2025 Posts: 2217 Rating:
Hi, There are a few controllers in APL library: PIDConL and PIDStepL Using the following algorithm:
PIDConR: Using the algorithm as dispayed in attachment I don't know the velocity method, but at least you know the algorithm that the controllers use.
6/2/2020 10:41 AM | |
Great! Good luck with development! |
