(1)| 7/14/2025 8:53 PM | |
Joined: 9/21/2022 Last visit: 11/13/2025 Posts: 12 Rating:
| 7/14/2025 8:54 PM | |
Adding the screenshots of what I have now vs what I want to display |
| 11/13/2025 9:45 PM | |
Joined: 4/28/2015 Last visit: 1/2/2026 Posts: 383 Rating:
Hi TJS17, The functionality you wish to add to your touched based panel does not exist natively. I am a little unsure of your desired outcome, but in theory some of the control options you could be generated manually via WinCC (although this would not be an "easy" task). Please see the below application example: https://support.industry.siemens.com/cs/de/en/view/109755452 Please note the above article relates to Sinumerik Create MyHMI / WinCC, for this you would need a suitable PCU / IPC, Create MyHMI / WinCC license on the NC and the required engineering software and licenses as well as a working knowledge of WinCC. I am unsure of your background / knowledge but this is really a job taken on by an automation or control system engineer. Hope this points you in the right direction
Luke |
