7/22/2025 12:32 PM | |
Joined: 3/10/2024 Last visit: 8/7/2025 Posts: 3 Rating:
When i open the measuring point browser there is no area on selection of areas how can i add? |
7/22/2025 7:59 PM | |
Joined: 2/1/2010 Last visit: 9/12/2025 Posts: 212 Rating:
When the "measuring point browser" in PCS 7 does not show any areas in the "Selection of areas" section, this typically indicates an issue with area assignment or configuration. Here are the most relevant troubleshooting steps: Check Area Assignment of Measuring Points Ensure the plant hierarchy is being set up in PCS7 way (not manually), and that areas have been generated accordingly and there are points assigned under these hierarchies and not all manually made reorganizations. User Authorization If your user account does not have authorization for the areas or measuring points, they may not be visible in the browser. Make sure the account(s) has the required permissions for the relevant areas. |
7/23/2025 6:24 AM | |
How can i check that i don't understand actually |
7/23/2025 1:13 PM | |
It's basically like I said. Maybe said in a different way will be more helpful, you can try this thread. https://sieportal.siemens.com/en-se/support/forum/posts/pcs7-measuring-point-browser/162579 |
