(0)| 9/16/2009 11:45 AM | |
Joined: 3/2/2007 Last visit: 11/19/2025 Posts: 999 Rating:
Hy, we are trying to use virtual masters in a simotion d445. A slave master “Stretch_VirtualMaster” is following the main master “Main_VirtualMaster”. When we start the main master, the slave master runs at the velocity defined in the “Dynamic response – Default” tab for a few seconds (100 mm/s), before following the master. Why is this happening? What does this velocity mean? Kindly, check the attached for details. Thank you
AttachmentVirtualMaster starting.pdf (493 Downloads) |
