08.03.2022 14:25 | |
Beigetreten: 18.12.2014 Letzter Bes: 02.09.2024 Beiträge: 33661 Bewertung: (4183) |
Update vom 08.03.2022 Andere: Ladies and Gentlemen, for your information: The following new advisories/bulletins have just been published on the Siemens ProductCERT web site [1]: SSA-134279: Vulnerability in Mendix Forgot Password Appstore module * <https://cert-portal.siemens.com/productcert/pdf/ssa-134279.pdf> SSA-148641: XPath Constraint Vulnerability in Mendix Runtime * <https://cert-portal.siemens.com/productcert/pdf/ssa-148641.pdf> SSA-155599: File Parsing Vulnerabilities in COMOS * <https://cert-portal.siemens.com/productcert/pdf/ssa-155599.pdf> SSA-166747: Scene File Parsing Vulnerability in Simcenter STAR-CCM+ Viewer before V2022.1 * <https://cert-portal.siemens.com/productcert/pdf/ssa-166747.pdf> SSA-223353: Multiple Vulnerabilities in Nucleus RTOS based SIMOTICS CONNECT 400 * <https://cert-portal.siemens.com/productcert/pdf/ssa-223353.pdf> SSA-250085: Multiple Vulnerabilities in SINEC NMS * <https://cert-portal.siemens.com/productcert/pdf/ssa-250085.pdf> SSA-252466: Multiple Vulnerabilities in Climatix POL909 (AWM and AWB) * <https://cert-portal.siemens.com/productcert/pdf/ssa-252466.pdf> SSA-256353: Third-Party Component Vulnerabilities in RUGGEDCOM ROS * <https://cert-portal.siemens.com/productcert/pdf/ssa-256353.pdf> SSA-337210: Privilege Escalation Vulnerability in SINUMERIK MC * <https://cert-portal.siemens.com/productcert/pdf/ssa-337210.pdf> SSA-389290: Third-Party Component Vulnerabilities in SINEC INS * <https://cert-portal.siemens.com/productcert/pdf/ssa-389290.pdf> SSA-406691: Buffer Vulnerabilities in DHCP function of RUGGEDCOM ROX products * <https://cert-portal.siemens.com/productcert/pdf/ssa-406691.pdf> SSA-415938: Improper Access Control Vulnerability in Mendix * <https://cert-portal.siemens.com/productcert/pdf/ssa-415938.pdf> SSA-562051: Cross-Site Scripting Vulnerability in Polarion ALM * <https://cert-portal.siemens.com/productcert/pdf/ssa-562051.pdf> SSA-594438: Remote Code Execution and Denial-of-Service Vulnerability in multiple RUGGEDCOM ROX products * <https://cert-portal.siemens.com/productcert/pdf/ssa-594438.pdf> SSA-764417: Multiple Vulnerabilities in RUGGEDCOM Devices * <https://cert-portal.siemens.com/productcert/pdf/ssa-764417.pdf> Additionally, the following advisories / bulletins have just been updated on the Siemens ProductCERT web site [1]: SSA-244969: OpenSSL Vulnerability in Industrial Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-244969.pdf> * Added solution for SINUMERIK Operate; Added Industrial Edge products SSA-301589: Multiple File Parsing Vulnerabilities in Solid Edge, JT2Go and Teamcenter Visualization * <https://cert-portal.siemens.com/productcert/pdf/ssa-301589.pdf> * Added remediation for Teamcenter Visualization version lines V12.4 and V13.3 SSA-306654: Insyde BIOS Vulnerabilities in Siemens Industrial Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-306654.pdf> * Corrected AV:L for all CVEs, added RUGGEDCOM APE1808 and SIMATIC IPC477E PRO SSA-309571: IPU 2021.1 Vulnerabilities in Siemens Industrial Products using Intel CPUs (June 2021) * <https://cert-portal.siemens.com/productcert/pdf/ssa-309571.pdf> * Added mitigation; clarified no remediation planned for SIMATIC S7-1500 CPU 1518F-4 PN/DP MFP; added solution for SIMATIC IPC127E and SIMATIC ET 200SP Open Controller CPU 1515SP PC2 SSB-439005: Vulnerabilities in the additional GNU/Linux subsystem of the SIMATIC S7-1500 CPU 1518(F)-4 PN/DP MFP * <https://cert-portal.siemens.com/productcert/pdf/ssb-439005.pdf> * Added CVE-2022-23308, CVE-2022-24407, CVE-2022-24448, CVE-2022-25235 SSA-462066: Vulnerability known as TCP SACK PANIC in Industrial Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-462066.pdf> * Readded SCALANCE S615 to the list of affected products SSA-501073: Vulnerabilities in Controllers CPU 1518 MFP using Intel CPUs (November 2020) * <https://cert-portal.siemens.com/productcert/pdf/ssa-501073.pdf> * Updated specific mitigations; clarified that no remediation is planned SSA-534763: Special Register Buffer Data Sampling (SRBDS) aka Crosstalk in Industrial Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-534763.pdf> * Added solution for SIMATIC IPC3000 SMART V2 and clarified that no further fixes are planned SSA-541018: Embedded TCP/IP Stack Vulnerabilities (AMNESIA:33) in SENTRON PAC / 3VA Devices (Part 2) * <https://cert-portal.siemens.com/productcert/pdf/ssa-541018.pdf> * Added download link of update version for SENTRON PAC2200 SSA-669158: DNS Client Vulnerabilities in SIMOTICS CONNECT 400 * <https://cert-portal.siemens.com/productcert/pdf/ssa-669158.pdf> * Added solution for CVE-2021-25677 SSA-669737: Improper Access Control Vulnerability in SICAM TOOLBOX II * <https://cert-portal.siemens.com/productcert/pdf/ssa-669737.pdf> * Updated Acknowledgments; Improved Mitigation Description SSA-678983: Vulnerabilities in Industrial PCs and CNC devices using Intel CPUs (November 2020) * <https://cert-portal.siemens.com/productcert/pdf/ssa-678983.pdf> * Added solution for SIMATIC ET 200SP Open Controller CPU 1515SP PC2 SSA-703715: Information Disclosure Vulnerability in Climatix POL909 (AWM and AWB) * <https://cert-portal.siemens.com/productcert/pdf/ssa-703715.pdf> * Added product: Climatix POL909 (AWB module) SSA-838121: Multiple Denial of Service Vulnerabilities in Industrial Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-838121.pdf> * Added solution for SIMATIC S7-PLCSIM Advanced SSA-840188: Multiple Vulnerabilities in SIMATIC WinCC Affecting Other SIMATIC Software Products * <https://cert-portal.siemens.com/productcert/pdf/ssa-840188.pdf> * Added Mitigation to CVE-2021-40358 |
