2/28/2022 2:25 PM | |
Joined: 2/28/2022 Last visit: 7/21/2024 Posts: 1 Rating: (0) |
Hi I am facing the problem with PLCSIM 5.4 form last one month Its showing every thing OK ,but when i try download program then showing following massage .Please help
Last edited by: Jen_Moderator at: 03/01/2022 09:46:20New subject after splitting |
2/28/2022 2:55 PM | |
Joined: 9/27/2006 Last visit: 11/16/2024 Posts: 12294 Rating: (2691) |
Hello Muhammadjaved; What interface have you selected inside the PG/PC interface, to establish a connection wetween Step 7 and your simulated CPU?? With PLCSIM v5.4, I believe you should select "PLCSIM" as the interface connection. See for example this document that applies to TIA Portal; the answer also works with Step 7 v5.x: https://support.industry.siemens.com/cs/ww/en/view/61931797 Hope this helps, Daniel Chartier |
