6/22/2024 1:53 AM | |
Joined: 3/26/2016 Last visit: 8/4/2024 Posts: 31 Rating: (0) |
Ok, to confirm the higher resolution (more bit) the more accurate the value will be since the PIW range will be larger? |
6/24/2024 6:10 AM | |
Joined: 7/9/2015 Last visit: 8/30/2024 Posts: 3943 Rating: (585)
Hi, no, the PIW range is the same but the values between 0 and 27648 inc have a higher accuracy. This is what I wanted to tell you in my last post... Also check this FAQ for understanding: Entry type:FAQEntry ID:39334504,Entry date:04/01/2016(114) Rate For an S7-1200/S7-1500 controller in STEP 7 (TIA Portal), how do you scale integer values in real numbers and vice versa for analog inputs and outputs?Regards, Towome |
