Industry Online Support
6/14/2010 2:00 PM | |
Joined: 8/31/2005 Last visit: 6/14/2024 Posts: 2198 Rating:
Hello, I found a document from Siemens Pakistan that tells me your motor has 315kW. 'Due this is the only document one I found at Siemens, I expect its not often in use and you will not get a answer here. You should make a support request to contact the hotline. |
6/15/2010 11:53 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating:
Hi, Pls check if this link helps to you http://www.setams.com.ar/manualessiemens/manuales_catalogos_siemens%5CD86.1_03.05_Ing.pdf DEEP. |
