Industry Online Support
10/18/2005 4:09 PM | |
Joined: 8/25/2005 Last visit: 7/5/2024 Posts: 1161 Rating:
Hello DEMI, I'm not a specialist in WinCC. But I found a FAQ which describe the migration from Coros to WinCC. Here the Link: Migration of COROS LS-B/FlexOS or COROS LS-B/WIN to WinCC Hope this is a first step to solve your problem. Best regards Sabine |
10/19/2005 8:29 AM | |
Posts: 3149 Rating:
Hello Demi, as far as I know, you can use in WinCC the S5-Channel, which is a WinCC-Addon. You can get more Informations here: http://www.industry.siemens.com/itps/it4industry/en/wincc/index1503863.htm Whether your CP is running with this driver, should you check with the it4industry-people. Good luck, Nemo[8)] |
