9/23/2024 5:40 PM | |
Joined: 3/14/2008 Last visit: 10/15/2024 Posts: 2111 Rating: (942)
Hi, PLCSim does not support named connections. Instead you need to use a TCP/IP or ISO connection. This means in an existing PCS7 project, you need to recompile the OS with the TCP/IP or ISO connection. PS: Route Control addon relies on named connections and thus you cannot use it with PLCSim. |
