(1)| 4/28/2025 2:44 PM | |
Joined: 12/12/2023 Last visit: 4/28/2025 Posts: 1 Rating:
still having issues with this. windows 11, tia v18. i changed the startup to automatic, still didnt work. uninstalled some buggy software (OCCT) i used shortly before issue started happening, restarted and still not working. help? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 04/30/2025 07:06:35New subject after splitting |
| 4/29/2025 9:55 AM | |
Joined: 2/10/2018 Last visit: 9/14/2025 Posts: 1 Rating:
Hi, I had the same problem today. Solved by installing Siemens_Automation_License_Manager_V6.2_SP2
| 4/29/2025 10:54 AM | |
Joined: 2/1/2016 Last visit: 12/17/2025 Posts: 1 Rating:
Here also, had an laptop with windows 11 and windows installed some updates then ALM service keeps crashing. Created lokal admin (user was in domain) and deinstalled the old ALM and then installed the latest one V6.2 SP2 and then it worked again. I think windows have released an update that caused problems with the Siemens Automation License manager application. |
| 4/29/2025 12:28 PM | |
Joined: 10/15/2020 Last visit: 1/5/2026 Posts: 1 Rating:
Same here! This was the solution for me too! For me the Important part was to uninstall 6.0 first, otherwise 6.2 would not install correctly! |
| 5/1/2025 2:48 PM | |
Joined: 4/24/2006 Last visit: 1/16/2026 Posts: 9105 Rating:
Hello Try to use the latest version of Automation License Manager (ALM) V6.2 sp2 Here a link to download: Handling programs for authorization or licensing of SIMATIC products (ALM, Authors) Best regards, Wizard |
| 5/5/2025 3:06 PM | |
Joined: 7/30/2024 Last visit: 1/16/2026 Posts: 1193 Rating:
Hello, The Technical Support is informed about the ALM-problem with the Windows 11 update and has provided a workaround for the issue:
Kind regards, Moderator_Lan |
| 5/7/2025 11:26 PM | |
Joined: 3/9/2025 Last visit: 8/12/2025 Posts: 1 Rating:
Hello, how is that working with licence transfered to PC? when I remove ALM to install newset will I loose the licence? |
