(0)| 6/16/2025 5:24 PM | |
Joined: 12/22/2021 Last visit: 1/20/2026 Posts: 80 Rating:
Hello SeoYoon-hee
Step 2:Click next to the bulb (white area) in theDynamicsection. Once the edit option is enabled, enter your tag name (only the prefix). I hope it clarifies your doubt! AttachmentAPL_Ref.zip (166 Downloads) |
| 6/16/2025 7:17 PM | |
Joined: 2/1/2010 Last visit: 1/14/2026 Posts: 218 Rating:
I think the above response is misleading. You should not be using Dynamic Dialog with block icons, period. It's not supported for using with block icon generation (which is how you would substitute the tag prefix during creation). You can see that no block icons are using dynamic dialog from out of the box delivery on the typicals page. Everything has to be made via customized object embedded animations / linked event scripts etc. which come from linked tags only. Read about the correct way to do it in PCS7 APL Style Guide. |
Last edited by: RVS.wick at: 06/16/2025 19:19:33Last edited by: RVS.wick at: 06/16/2025 19:23:43If my post helped you, please rate. Thanks. |
| 6/18/2025 9:47 AM | |
Thanks for information, I'll follow the APL Style Guide approach |
