(0)| 7/9/2025 11:43 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello MGrenaaT Which Version do you use of TIA Portal, perhaps it has also something to do with: https://support.industry.siemens.com/cs/de/en/view/109795137 you can also try to use an IO Field with this tag in the Screen. If it works then, it could be that you have to set the acquisition mode to cyclic of this tag Bye Murof |
