(2)| 8/22/2023 1:05 PM | |
Posts: 3 Rating:
Hello. I got the same problem with a frequency inverter 6SE7021-8EB61. I also use an usb-rs232 konverter. I want to connect through PMU X300. My settings of P700 - P703 are the same you specified. But it does not work. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/14/2023 09:44:07New subject after splitting |
| 8/25/2023 8:59 PM | |
Joined: 10/17/2007 Last visit: 1/12/2026 Posts: 4573 Rating:
you did not mention your cable, see attached drawing, if all good, it is also possible defective of X300
AttachmentRS232 Cable_PC_to_X300.pdf (1033 Downloads) |
If you like my comments please |
| 8/31/2023 9:44 AM | |
Posts: 3 Rating:
Hello! Thank you for the answer. After checking all settings in frequency inverter and laptop, the cable was wrong. Thank you both for the help! |
