4/11/2024 6:15 PM | |
Joined: 4/26/2012 Last visit: 6/25/2024 Posts: 1547 Rating:
Hello, see if it helps you. I have one user per group, so I use "GetGroupNumber". Otherwise, you would have to try to assign a value to a variable every time you log in and out and use that value for your control. There is a situation where if you lose power to the HMI, you will be left without this record. Could you give more details about your event logging? Is there any way to access the user's "number"? Here are some comments, LINK good luck.
Last edited by: rdoliveira at: 04/11/2024 18:18:34image "Always make a backup before and check the best time before testing." |
4/12/2024 12:54 PM | |
Joined: 8/3/2009 Last visit: 6/26/2024 Posts: 13139 Rating:
Hello Jazzgeek you can also use this for logging the login/logout events in alarm loggin: https://support.industry.siemens.com/cs/de/en/view/109758223 Bye Murof |
4/29/2024 4:47 PM | |
Joined: 10/16/2012 Last visit: 5/10/2024 Posts: 36 Rating:
Thank you Murof! I think this is probably the best way to go. Jeff |
