(0)| 12/18/2025 10:37 AM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16644 Rating:
Hello If you have more that 8 PLC Connections the Softnet S7 Lean License is not enough: Check out this FAQ: https://support.industry.siemens.com/cs/de/en/view/21914909 But this should not lead to a connectino interruption. you could try to check the error logfiles in the WInCC Dianose folder in the WinCC Installation folder. Perhaps in the S7 Protocol Suite or S71200/1500 Logfiles are some additional information or error codes
Bye Murof |
