12/11/2018 3:45 PM | |
Joined: 9/27/2006 Last visit: 9/18/2025 Posts: 12414 Rating:
Hello antonio; Products from Siemens Building Technologies are not easily accessible outside of that division, and information is not easily gathered from our side (Siemens Industry- Automation and Drives). The standard datasheet for the MVL661.20-2.5 refrigerant valves only mention the same refrigerants that you show in your post. There is no mention of R449a. https://www.downloads.siemens.com/download-center/Download.aspx?pos=download&fct=getasset&id1=10473 I can only suggest that you continue this search with SBT personnel, using their Contact meassaging address: www.siemens.com/bt/contact This can be found on the support webpage for SBT, where you can find further ressources. https://www.buildingtechnologies.siemens.com/bt/global/en/support/Pages/support.aspx?opentbb=1 Hope this helps, |
12/13/2018 1:35 PM | |
Posts: 6 Rating:
Thank you Albis, this is what I was looking for. Are you based in Zug? Antonio |
