(1)| 2/24/2023 10:17 AM | |
Posts: 6 Rating:
Why I can't Add a Diagnostics Address Kindly Give an Explanation. Thanks In Advance... |
| 2/24/2023 10:31 AM | |
Joined: 1/21/2013 Last visit: 12/24/2025 Posts: 4365 Rating:
Hi Single_321, you should define the monitoring in the symbol table, function block or function. Further information can be found in chapter 9 of the manual 'S7-PDIAG for S7-300 and S7-400 Configuring Process Diagnostic'. Kind regards |
| 2/24/2023 11:55 AM | |
Hi Single_321, take a look at this video: https://youtu.be/k8ilmYBAO-4?t=1751 Kind regards |
| 2/24/2023 12:02 PM | |
Posts: 6 Rating:
Thanks for the Help... If Any is Required I will Chat |
| 2/27/2023 5:27 AM | |
Hi Single_321, you should find an example program on your computer. Please select "Open Project" in SIMATIC Manager and select "Sample projects". You should find a project "UEn06_01_STDIAG_drill" in the list. The description of the project can be found in chapter 19 of the manual 'S7-PDIAG for S7-300 and S7-400 Configuring Process Diagnostic'. Kind regards |
