(2)| 4/1/2025 3:03 PM | |
Joined: 5/29/2024 Last visit: 1/15/2026 Posts: 123 Rating:
Hi Manik! Have you tried the instructions mentioned on page 947 of the following manual: -> S7-200 SMART Hope it helps! |
| 4/1/2025 3:17 PM | |
Joined: 4/10/2020 Last visit: 1/7/2026 Posts: 8 Rating:
Hi ALP00, Thanks for your reply. I have already tried the instructions but still issue is same. This issue only show when the actual date is changed to 26 January. Before that there is no issue. If I change my Laptop current Date to previous date and save as the project in back date then there is no issue. From 26 January to till the day the PLC timestamp comparing time changed to 1984 while the RTC of PLC is working fine. Best Regards. |
