7/9/2025 12:10 PM | |
Joined: 8/3/2009 Last visit: 9/19/2025 Posts: 16461 Rating:
Hello AutoGen_8061130 A good solution for you could be to use WinCC Unified Collaboration. Here you can access the screens of the other HMI as needed. some information how it works you can find in this example: https://support.industry.siemens.com/cs/de/en/view/109896068 But unfortunately if is an Option and you will need additional licenses Bye Murof |
