6/4/2010 5:44 PM | |
Posts: 2 Rating:
Hello, I am new to the forum and seeking technical advice. We own a 20000SF commercial building in Orlando FL USA. The building is 1600A service @ 120/280V, 3PH, 4W and was built in 2004. Installed at construction was a Siemens TPS unit with three phase protection and a counter. The device is failing. Our electrical engineer advised us to replace with a Current Technology TransGuard300 and his reasoning was that we needed a higher quality device and the exact unit we had was no longer manufactured by Siemens. This structure is in a major lightning area and is recording as many as 500x hits a month in the summer. I want to kick around these idea with a Siemens group before we make any decisions. Can you help? Am I even in the right spot? Thanks, Brock Splitted from Tips&Tricks for the forum usage. |
6/7/2010 8:14 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
Thread closed, because question is already published in the following thread Need advice on commercial building surge protection.... Best regards O_Moderator |
