12/23/2020 5:01 PM | |
Posts: 2 Rating:
Hi, I would like to know if it is possible to use SQLEdge with IOT2050 device, and there is "IOT edge" already implemented. Thanks |
1/5/2021 4:58 PM | |
Joined: 12/12/2016 Last visit: 7/25/2025 Posts: 640 Rating:
Hello Francesco, As far as I understand, Microsoft is providing a Docker container for Azure SQL Edge and supposedly also for ARM64 so I would give it a try. For this you would first have to build an IOT2050 Image using this tutorial as the current example image does not support docker (but on master branch this is fixed). Afterwards you can install docker using the regular steps for Debian (have a look at the official docker website). Then you can continue to follow the steps on the Microsoft website for installing the Azure SQL Edge Container. BR |
1/5/2021 5:14 PM | |
Posts: 2 Rating:
thanks, I will read the instructions carefully |
