7/20/2022 7:57 AM | |
Joined: 7/13/2022 Last visit: 2/28/2023 Posts: 17 Rating: (0) |
Thanks for your reply. The advice about overlapping memory addresses actually solved one issue. I've added the projects as an attachment. The folder 'lwe1' contains my LWE project and 'Circuit Diagram 2' is my function block diagram. Could you please tell me more about why the switch button labeled 'tuesday doesn't seem to work'? AttachmentScheduled Output.zip (245 Downloads) |
7/20/2022 9:19 AM | |
Never mind this question, I've done some more testing and I'm going to make a new post with a rephrased inquiry. |
7/20/2022 9:23 AM | |
Joined: 12/18/2014 Last visit: 5/2/2024 Posts: 32924 Rating: (4072)
The switch button labeled "Tuesday" work. By the stopwatches have you not change the time base by "minute" and "hours". The all have the time base secondes. See attached screenvideo. AttachmentWebserver.zip (237 Downloads) |
