4/22/2021 8:18 PM | |
Joined: 5/27/2020 Last visit: 7/9/2024 Posts: 28 Rating: (2) |
Hello, I am having the same problem. Is it possible to give a bit more detail on your solution? Many thanks |
3/31/2022 1:36 PM | |
Joined: 11/18/2010 Last visit: 7/18/2024 Posts: 14 Rating: (0) |
Hi there, Can you please share us how did you update the image for HMI? Or just copy the image to project folder |
11/3/2022 2:15 PM | |
Joined: 4/1/2021 Last visit: 11/3/2022 Posts: 1 Rating: (3) |
When you want to update image file manually, you first must download image file from here, and you mast copy-paste download file (firs adaptation file) to this path C:/Program Files/SEMENS/AUTOMATION/Portal V.../Data/Hmi/Transfer/V.../ and image file to this path C:/Program Files/SEMENS/AUTOMATION/Portal V.../Data/Hmi/Transfer/V.../Images/ . And that should solve the problem. Version of image file you choose according to the versions you want to upgrade, that is, you choose according to the project in WinCC. |
